Carby specs
  • Carby specs
    Hi
    I have a 1997 2 stroke 3cyl 70ltrv yammy out board
    I'm rebuilding all the carburettors with new kits and floats, can someone
    Give the the correct info on how to set the floats and how to
    Sync the 3 carbies together.? And the correct specs for adjusting the mixture screws. Cheers thanks
    Idle mixture screw setting is 1 & 1/4 turn outward from the screw being lightly seated. Plus or minus 1/4 turn.
    Float height is 14 mm. Plus or minus 1 mm.
    The adjustment procedure is too detailed to describe here. Photos are needed with the words. Suggest you get a Yamaha service manual and follow the procedures described therein.
      Thanks heaps mate, what site do u recommend for a good repair Manual for that model outboard. Cheers
        www.simyamaha.com
