PORPESING BOAT
  • PORPESING BOAT
    when running up on plane with my 21ft seapro w/a with 200yam seaox 66 motor trimmed all the way down and trim tabs in the up position if i trim the motor up at all the the bow will porpose.i do gain speed and rpm when trimming up but its to rough of a ride. is there something to cure this other than not trimming the motor? thanks for any help.
    There's always many factors that result in porpoising hulls. Load balance, type of prop, motor height are a few. Are you using a 3-blade or a 4-blade prop? When you're running on plane is the motor's cavitation plate above the waterline? If not, raise it a hole at a time till it is. Try tapping the trim tabs down a little at a time to stabilize the boat, but only as much as necessary (drag). If you have a 4-blade prop available try that, they usually offer better grip and control of the boat's behavior.
    Mike
