2005 250hp Yamaha runs great , at 3000/3500 rpms spews oil out of breather tube , been to certified shops can't find issue . Passed leak down test , changed oil pump , can't find problem need help !
Oil spewing out of breather tube !!!
I am presuming this is an F250 (four stroke) and not a 250 (two stroke) Yamaha.Originally posted by floridafishing View Post2005 250hp Yamaha runs great , at 3000/3500 rpms spews oil out of breather tube , been to certified shops can't find issue . Passed leak down test , changed oil pump , no oil on plugs , can't find problem need help !
Blow by out the breather tube generally indicates a worn cylinder and/or piston rings.
A leak down (sic) differential pressure test can be a teat on a boar hog.
Think about it. With a differential pressure test the piston rings are at the upper most part of the cylinder. Where the wear in the cylinder will be the least. The rings may be sealing just fine there, but not sealing so well at all of the areas of travel down below.
Perhaps the cam shafts need to be removed so that all valves remain closed while another differential pressure test is performed with the piston somewhat down into the cylinder.
Or, maybe a bore scope should be sent down the spark plug hole to check the condition of the cylinder walls. Maybe one or more is scored down below which might not effect a top dead center differential pressure test.
Where the hell is rodnut?Last edited by boscoe99; 07-08-2016, 12:03 PM.
Piston ring blow by, worn rings..
The crankcase is being pressurized by compression from the top end blowing oil out..
Had it on a dodge slant 6 that would blow 5 quarts out the dip stick hole in 10 miles.. Rings had an end gap of about 1/4". A new set of rings, it was just inside spec's. BIL drove the car for many years after that..Scott
Same thing. Should be venting into the air intake (for re-burn & emissions)Originally posted by robert graham View PostIf this is a 4 stroke motor doesn't the crankcase have some type of ventilation valve or line????Scott
I can't imagine how the system itself would malfunction. It is just a tube from the crankcase to the air intake.Originally posted by robert graham View PostWould a malfunction of this system give the OP his oil spewing problem?...seems like this system would be a good place to start checking?...
I am guessing the oil is being spewed out of the breather tube and into the air intake system and causing the motor to run like crap and/or making a mess of the throttle valve. So much gas is escaping so quickly that the air/oil separator function of the motor cannot do its job.
Reminds me of '62 Ford Falcoon I once had. Every time I stopped in traffic I was surrounded by billowing exhaust smoke. To minimize my embarrassment I tried routing the breather hose to the intake but it made a mess of the carburetor in short order. Damn those were the good ole days.
can someone help me???
