F250TUR drive shaft frozen
  • F250TUR drive shaft frozen
    I jumped into another project, I'm converting my 30" motors into 25", It is not starting out well, I went to drop the lower and the shaft was froze up in the crankshaft, I tried all of the usual, shims, hammer, a bigger hammer, then I just cut the driveshaft since I really didn't need it anymore, then I drilled the shaft, tapped it and fashioned a puller if you will, my question is why does the shaft rust so bad on these things, I have heard of this happening but I have had yamahas for the past 25 yrs and never had a problem, I did grease my splines every 2 years or so, I am wondering why the seals in the bottom of the oil pump don't keep the moisture out?
    Welcome to salt water!
      25 cents worth of grease once per year solves that issue.
