But synthetic oil DOES start out as normal, crude oil from the ground. It's just modified to be a purer, chemically superior product. Don't get me wrong - I'm not putting down synthetics - I do use them for certain applications. I was just always under the assumption, until recently, that synthetics were derived completely of man-made products... not that they started their life as regular oil. I only wanted to pass this info along as I thought it was interesting and others might find it so, too.
This is from Mobil's website:
"Conventional and synthetic oils begin in the ground. But that’s where the similarities end.
Synthetic oil is not only refined but also distilled, purified and broken down into its basic molecules. This process not only removes more impurities from the crude oil but also enables individual molecules in the oil to be tailored to the demands of modern engines. These customized molecules provide higher levels of protection and performance than conventional oils. But the synthetic base oil is only half the story. The correct blend additives must go into the mix to create the oil."
