Originally posted by boscoe99
View Post
6y5-8350t-83 tach wiring diagram
Originally posted by 99yam40 View PostI hope you have not been putting 4 stroke oil in the oil tanks
Hey, I guess I did know they were two stroke motors all along.
Man, Alzheimer's is a bitch!
Originally posted by Joediveguy View PostEngine #1...........
Do both motors have square nylon connectors? Or does one motor have square connectors and the other motor have round connectors?
Originally posted by Joediveguy View PostYes one motor has round and the other has square connectors.
Can you tell by the pictures which harness I will need?
The motor with the round connectors uses the same trim/oil harness (from the motor to the gauge) but adapter harness are needed. See the following illustration.
Now that I think about it, both of your motors use a three wire trim sender. The sender gets its voltage from the tachometer. Via the orange wire.
Originally posted by boscoe99 View PostThe motor with the square connectors will use the harness that is depicted in the illustration in my post #11. Unless you string a single wire for the trim.
Can you tell me what the part numbers are for the wiring harnesses that I will need for each engine? One for the SQUARE connectors and one for the ROUND connectors? That way I can just order the parts and be done with it, hopefully.
Thanks, Joe
ÂÂÂÂÂ
