Hi all ,
Yamaha 70 1995 , 2 stroke BETO
Is I was advised - I'm starting a new thread.
as my trim was leaking, i took the boat out and replaced the trim seals.
All went ok, no modifications to the engine were made.
I took the boat after a month in water and i noticed that won't go above 22000-2500 RPM - 2 person on baord. With me only it came to 3000-3200 RPM.
I thought that may be starving for fuel, so i changed the hoses, primer bulb, new tank. With this nothing resolved, stil wont go above 3000 RPM (my onla onboard)
I bought new spark plugs, instaled them, all the same -same problem.
Then i took the carbs off, and toght that maybe was a problem with jets - all was ok, the carb is clean, the jets are clean -the carbs are like new.
What could be the problem ???
It idles fine, it goes to 3000 RPM very nice, just when you press the lever to go above 3k, it sounds buaaaaaa, then you put the lever back it cames back to 3k.
I wil try to test the coils for continuity with a ohmmeter and see that.
Please help
P.S. The primer bulb is ok even on 3000 RPM , the fuels goes fine.
Please help
