first of all thanks to anyone that may be able to help me out. im not super knowledgeable with outboards so please bare with me.
i have a 1988 yamaha 30 hp precision blend outboard, model 30 ESG 2 stroke.
Here is the story. a few years ago i was low on money so i let it sit for a couple years. (ran perfect before this time). finally got a better job and started digging into it again and wasnt firing up. took apart the carbs and were filthy so i cleaned them out real good.
just started working on it again, took carbs out once again and recleaned every little part imaginable with the help of my father. jets and all. replaced fuel filter and fuel pump as well. before we fired it back up we put new gas in tank and new oil in reservoir. we also cleaned out all the lines leading to the carburetors.
we seem to be having problems with the gear linkage adjustment and carburetor adjustments the most. we could keep it running with the choke barely opened but once the choke was closed it died shortly after. what was odd was we put the lid on and i came back down the next morning (last week) and started it up and within a few seconds it stayed running without the choke at all. it idled high for a little bit then started sounding like it used to (nice low idle). so just today i came back down without making any adjustments and tried it again and it wont stay running unless its choked a little bit, second i close it it will idle high then bog down and die shortly after.
i found the specs for the enrichment screws which are top 5/8-1 1/8, middle 1 1/2-2, bottom 3/4-1 1/4. we had them set at 1 3/4, 2 1/4, 2 1/2. so i tried fiddling with the spec adjustments and cant keep it running without choke.
also, when i took apart the bolts that mount the carbs i lost all 6? small bolts i think they were around 3/4 long, but all the long ones are in and secure so maybe there could be a slight vacuum leak?
finally we are having problems keeping forward, neutral, and reverse all working. cant keep it in reverse at the moment. does anyone know where i can find the original specs for all of this so we can reset to where it is supposed to be. it seems like its 90% ready just got to figure all this timing stuff out. thanks
Dan
Dan
