I purchased an 01 F30LTZR that will not run with the "primer starter assembly" sitting in its place on the top carb. When I take it out it will run ok. The guy I purchased it from gave me a spring he said that came out of the primer starter assembly. It is a fair gamble to buy the $300 part, or wait a couple of weeks for my mechanic to return? Im dying to use it, and the part looks simple to replace. Also, what does this part do exactly, and will it by itself prevent the motor from running?
The Primestart device provides extra fuel when the engine is cold to facilitate a cold engine start. Similar to what a choke does. Once the motor is started and running the motor starts to warm up. So too does the Primestart device. As the device warms up it provides less and less extra gasoline. When the motor is fully warmed up and the primestart device is fully warmed up it stops providing extra gasoline altogether
Not sure what your question is about when you say "will it prevent the motor from running." I thought you said you removed it and the motor will run.
The motor needs to go to the mekanik doctore for an inspection and some minor surgery.
