Just replaced the impeller (kit), thermostat and poppet valve (pressure relief valve) in my 1987 Yamaha 90 and I have a question.
I noticed that when first run up it got pretty damn hot, hot to touch the cyl head and the tattle til pee stream was pretty hot too. Never noticed it get this hot before the changing all of the above so I shut the engine down to let it cool off. Then I started it 15 mins later and it's holding a nice normal temp and is hot but not burning hot to touch and piss stream is cold (as usual, prior to changing parts).
Question: is it normal for this motor to get pretty darn hot prior to the Tstat opening? I have not noticed this before, I suspected that the Tstat was stuck open, that why I changed it out here. It was always running on the cool side in my opion.
Help and advice appreciated.
Also - very certain everything I installed was correctly fitted. Double and triple checked. Additionally - had the cyl head water jacket off when changing the Tstat. Not sure if this has any effect. Can you get trapped air in boat cooling systems? As they are open systems I wouldn't think so...
