Maybe someone can help me. I have a 1992 25hp MLHQ that was stored in a barn for around 10 years while work kept me from having any fun. I brought it to an authorized yamaha dealer for a tune up and check over to get it up and running again. The dealer says it has a bad cdi box because some mice got in it and chewed up some wires. Apparently that part (#6L2-85540-10-00) is no longer made and is called obsolete. Is there a replacement for this part? Does anyone know where I might find it? MY dealer is looking and I did a search of the internet and could not find it available. I did find this forum though. Has this part been replaced with a different technology? Is there some aftermarket fix? This motor has very few hours on it and I don't want to abandon it.
can not find a cdi assembly for 1992 25MLHQ
Is there a stub left for the chewed wires? If so I would be cutting splicing. All that is needed is about half of a butt connectors length to splice onto.
http://www.marinepartsoutlet.com/yamaha_parts.htm
http://www.cdielectronics.com/produc...epair-service/Last edited by boscoe99; 06-05-2016, 03:02 PM.
might try simyamaha
I punched that part # in and it did not come back as not available when it came up. but you can always call to make sure
CDI UNIT ASSEMBLY
but Boscos recommendation should be cheaper
boats.net shows it at $555 but not available.
6L2-85540-10-00 YAMAHA CDI UNIT ASY
It is no longer stocked by Yamaha USA. Discontinued part.
Thanks to you guys I found two possible sources for the cdi. One new one at Sims, and one used one at Ebay I gave the info to my Yamaha service dealer and he was going to check them out. Stand by, I will let you know what happens. Thanks all for your replies.
