2002 dx150tlra ox66. The relay has a constant hot(12v) red wire coming from the 30amp fuse, and a blue/yellow stripe that energizies the relay. The blue/yellow goes straight to the ecu which I think that the ecu should ground. If I ground the blue/yellow the main relay energizies like it should and make the red/yellow hot for the fuel pump ect. When I ground the blue/yellow the fuel pump runs like it should and turns off like it should. There are not trouble codes.
Should the ecu provide the ground? What tells the ecu to ground this?
What do I need to check, is the ecu bad.
Rodbolt you out there you seem to be the genius?
