Hello everybody,
I'm trying to disassemble the gear-case for a complete overhaul and I'm a bit stuck. I managed to remove the parts showed in green in the attached image and I don't know where to go next.
Do I need to pull out the bearing housing ( 25 ) to free the shifting rod ( 60 ) ?
Is the shifting rod holding the prop shaft assembly to come off?
Or should I remove the drive shaft (37) first, also?
The thing is a screw holding the bearing housing has broken off and now it needs to be removed by spark erosion but I need to know if it's really necessary to remove this housing.
