I am considering a repower on my 1806 Pathfinder. I currently have a 2007 90TLR and top out between 33-37 WOT @ 5200-5400 RPM depending on the load.
I have a couple questions:
I have a poling platform so clearance with a bigger motor is a concern. Here are some pictures of my setup. The motor is all the way jacked up on the jack plate in the photo. I can trim the motor all the way up with the jack plate up with about an inch of clearance. I am having trouble finding detailed measurements on the VF115LA to figure out if I have enough clearance for this repower.
This is the only spec sheet I could find on the 115:
Without having exact measurements, do you guys think the 115 would fit? I would be ok with the setup even if I could only trim all the way up with the jack plate down. Would I be able to remove the cowling under the poling platform?
Next question is how much of a performance improvement could I expect with this setup? I will probably keep this hull for a while and figure I could probably get about $3500 for the 90. Its a 2007 with less than 200hr on it and runs like a top.
I will try and update this post with some measurements of the clearance on my boat. Thanks.
