I was cruising at near full speed, I would loose power and the RPMs would rev up, just as if the prop was spun. My prop was nearly new and hadn't taken any hits or damage but changed it out anyway with a brand new one I had, same issue. A couple times I could get nearly up to speed and ride for a min or two then it would happen again.
This happened last fall, a lot of leaves in the water and a guy at work mentioned I was probably hitting patches of leaves slightly submerged out of view... but this went on many times that entire day in many wide open areas with no visible leaves.
It wasn't slipping out of gear because as I slowed I would regain power. I recently drained my lower unit and refilled. Dark-ish color but no metal flakes or water present. The oil seemed low though, but couldnt get the top screw out until the next day so its hard to say how low, if at all. I changed it myself about two years ago and know that I filled it then. If a seal is bad wouldn't that also let water in?
I'm not sure what else the issue could be, hoping some can give me some insight or other things to check.
I have a 2000 9.9 2 stroke converted to a 15. Been riding this for nearly five years with the same pitch prop, same load, same tilt etc.
