Originally posted by 99yam40
View Post
Either test can have it idiosyncrasies. Either one is not the be all end all. Despite Mr. Rodnuts opinions to the contrary.
Think about where the piston rings are when the differential test is being done. At the top of the cylinder. Where the wear will generally be the least. It is possible for there to be nil wear at the top of the cylinder and considerable wear lower down in the cylinder where the piston ring speed is the fastest.
It is possible to have 0% loss of air during a differential pressure test but for the engine to have considerable piston ring/cylinder wear that will affect the outcome of a compression test and the performance of the motor.
Now why two separate motors would have less compression on the same side and at the same values is the mystery. I don't see a cylinder head as causing the problem. Piston ring and cylinder wear, possibly. But still strange for both to have the exact same situation.
