I need to access the inside of my tiller arm to repair the gear shift cable attachment. I see the two screws that hold halves of the tiller assembly together but one is under the twist grip. How do you remove the twist grip? is the throttle cable easy to detatch and reattach? Is opening this assembly while docked/ over water likely to cause more problems than it solves? (ie lots of small parts, like springs, jumping out uncon*****ably)
thanks for input
thanks for input
