I have a 2007 150 Yamaha 4 stroke and I am trying to change the fuel filter on the front of the engine. I can not seem to loosen the clear bulb containing the filter element. HELP
fuel filter
+1 on cooling / shrinking it ^^^^.
Once your done (and its off) and re-assembling, make sure it goes on fully and seats with the 0-ring. I have a slightly different set up(no water electronic switch in the bottom) so my cup just goes straight up and a large plastic nut holds it on place.
Your cup is well over $100, my plain one is about $10.00 which I've changed out twice due to swelling..
Zip Tie Question
I'll call them zip ties for this question......Are the zip ties used to secure the fuel lines on the engine fuel filter anything special? Do I need to use some special rated type or will any old zip tie work?Originally posted by TownsendsFJR1300 View Post+1 on cooling / shrinking it ^^^^.
Makes sense on the ties. Other than fuel separator I haven't had to do anything fuel related, yet. Don't want to blow the cowling off the motor like "transmission stop leak fluid" guy was talking about a few weeks ago. But I need to change that filter and I might as well put it freezer because I have never touched it... Gives me a reason to go to fav boat supply store too, NOT west marine btw
That filter is yamaha specific, so you need the correct one.
I can about gaurentee that cup has swelled. I don't use ethonol and still get some swelling.
Just make sure, you get the cup fully back up there and the 0-ring seated.
If yours is like mine, there's a RED plastic RING, that's supposed to float if water is inside. It IS a PIA as it just barely slips around the lower filter and likes (really likes), to fall off while trying to install it.
I've found slipping the filter / ring up there first, THEN install the cup works the easiest...
And put a rag stretched out at the bottom to catch anything...
You shouldn't need any zip ties at all for changing that fuel filter and /or cup..Scott
he will if he wants to put it in the freezer, as he will need to remove the whole thing from the motor.
hard to get the whole motor in the freezer.
do not forget to drain the fuel out the best you can before putting in plastic freezer bag and then into freezer unless you want the good old gas smell all over inside where your food goes
I believe you ONLY need to freeze the cup and shrink that down. The main mount DOES NOT SWELL. I've replaced the cup several times and the new cup fits easily..Originally posted by 99yam40 View Posthe will if he wants to put it in the freezer, as he will need to remove the whole thing from the motor.
And a yea, I don't think the entire engine would fit in the freezer, great deduction..
