Oil injection removal 1998 yamaha 200hp two stroke
  • Oil injection removal 1998 yamaha 200hp two stroke
    Would anyone assist me on the proper way to disable the automatic oil injection system without removing any unnecessary parts. The goal is to premix manually.
    regards,
    Sev.
    As asked in the previous thread about this today, why do you want to remove it? Faulty (rare) paranoid ( probably) or just "because"
      Thanks for your quick reply my computer was down until today.
      I have now a worse problem. The engine cranks but wont start there is no spark from the spark plugs. Had to rewire Ignition but it ran fine the first time. Now it just won't fire at all. The original question was because the oil from the reservoir stop flowing to the small reserve in the engine block. Some people recommended that it would be easier just to pre-mix oil and gas in the tank. I don't really know if it is a good idea.
      Thanks,
      Sev.
        Just fix the oil system, do a search here on precision blend, it has been covered over and over and over and over.......
          thanks for the information. i will certainly do that.
          Regards,
          Sev
