I had to repair the tilt/trim Rams leaking oil sure some water got in their,rebuild went fine no problem their...however after adding 1 1/2 Qts of oil I am still getting foam/milky oil out of the reservoir fill hole and a bit of pressureized air when I remove the fill plug.I have cycled/purged the system 15 times or more,Rams work fine no leaks......should I drain the oil if so is their a drain plug or remove lower oil line?? And I did remove old oil from all the cylinders and reservoir.....I just found this site and I think it GREAT...Thanks Brad
Tilt/Trim Bleeding
