90HP Yamaha Steering Problem
  • 90HP Yamaha Steering Problem
    I have replace my steering on a 90 HP yamaha. It was tight getting the cable through the motor sleeve and now it seems locked up. Anyone ever seen this problem before? I am at a loss for an answer
    you need to clean out the tilt tube. i would take a small rod with steel wool wrapped around it and turn it with, say a cordless drill on low speed. also be careful to not bend the cable shaft going thru your tilt tube or your sterring will always be tough.lube the cable end very well prior to installing cable.
      Re: Steering is stuck after sitting all winter
      Just fixed mine......The motor is a 1988 Yamaha 90 2 stroke with a Teleflex mechanical steering cable. The problem is that when not used frequently, the grease becomes very hard (like cement) and causes the steering tube to "freeze" up.
      As discussed in this thread, try to get the cable out of the motor. (Use liberal amounts of WD-40, liquid wrench, penetrating oil, etc.) You will probably need to use a wood block and mallet to tap it out.
      When removed......I used liberal amounts of slovent and bought a 5/8" Masonary bit (13" long!) from Home depot. Be careful and try to turn the bit very slowly so as NOT to cause it to wobble. One the "gook" is cleaned up, use a wire brush (shotgun cleaning kit) and polish the tube.
      Lubricate it thoroughly prior to reassembling. It will work better than new!
      Guitar1
      P.S. Don't forget to replace the O-Ring......That's probably how the water got in there and froze it up in the first place!
        stiff steering
        90 yamaha , 1984 , in boston whaler, can you heat to un-freeze steering cable where it meets the engine after disconnecting it from the engine?
          Why don't you guys with cable steering just buy that that big steering nut with the grease fitting?? $15 or close to that??
            were can I purchase nut with zerk fitting on end
            Mine is not installed open, maybe because I have long shaft outboard and the angle? Do not use steel wool it will cause rusting from left over metal and serious seize it up.
              Noticed one at West Marine. Jamestown has them also.
