Tilt/ Trim
  • Tilt/ Trim
    my 02 90HP tilt trim slowly drifts down, is there anything other than the seals in the hyd cylinder that could cause this?
    Have you top the PTT fluid level?
      There is a manual release that may be bleeding by if not seated properly
        tilt trim
        will add fluid thanks for info
