OK I see there have been other threads that touch on this a little but I need all the help I can get with this one.
A week ago, after a day of fishing and putting the boat on the trailer (engine tilted full up) I noticed a strong fuel smell with a large quantity of fuel dripping out of the front of the cowl below the plastic fuel filter. It was raining so I just trailer-ed home. By the time I got there there was little smell and fuel had stopped dripping. The next day I removed the cowl and squeezed the ball. No leaks , no fuel smell, engine was dry. Ran the engine in a bag for a good 1/2 hour no leaks or fumes noted.
Concerned about fire, I called my mechanic friend and he told me to bring it over. Once there we took off top plastic cover (to inspect hoses on top of motor) and ran the engine for an hour, No leaks no fumes. Took the boat home (after tilting the engine up again and no fumes no leaks.
Later that afternoon took the boat for a ride and engine purred. Stars right up. Smooth running and 6100 RPM convinced me the problem was somehow gone. Pulled back to the ramp and as soon as the engine was tilted up a large sheen of fuel was seen behind the boat. i reached down and the raw fuel running out of the forward part of the engine filled my hand twice. Unfortunately right then it started raining very hard and it was impossible to remove the cowl. Got home the next morning and no residual fuel, no fumes, no leaks. pressurized the filter by squeezing the ball, with the lift pump running, tilted the engine. No leaks no smell, ran the engine again and seems to start and run fine. Tomorrow I plan to run it on the water and repeat the previous steps but tilting the engine with the cowl off and flashlights in hand.
I do swear that both times this happened there seemed to be a small amount of oil in the splashwell too. Something I have never seen. Oil level is normal and no fuel there.
One more question is there a drain hole in the front of the engine? I see none so I;m wondering how the fuel in coming out without a puddle of residual somewhere in the front. Maybe another question is there a check valve in the system that could stop fuel from draining out of the air intake? if anything it seems like a slight fuel smell is coming from behind the plastic air cover on the front of the engine but very minimal.
Any ideas or help would be greatly appreciated.
