New to the forum and only a Yamaha owner for less than a year.
I removed and sold a 1988 Yamaha Excel 225 from my boat. I replaced that engine with a 2000 Yamaha 250 OX66. The boat, a restored 1988 mako 211, has perfect wiring which I am fearful of messing up. I have a harness and oil tank that came with the 250 purchase.
1. Any issue in using the original 10 pin wiring harness?
2. The original owner installed a newer oil tank, not blue plugs. Can I use tank if I wire direct?
3. Any way to get around pulling instrument/trim harness? The boat currently has round plugs, not square. Was given newer key switch/harness with new engine.
4. Will existing Yamaha single binnacle work, the shift/throttle cables look the same
5. Can the existing harness be used?
6. I have purchased a new support rod for the sea star and a new Yamaha rigging adapter to thread the rigging tube.
7. The engine is on a stand being prepped for painting
Any advice would be appreciated
