Oil leaking behind fuel pump
  • Oil leaking behind fuel pump
    My Yamaha F20ESH is dripping oil from behind the fuel pump. I've removed it and the O ring looks fine as well as the block where it seals. The plastic spacer doesn't appear to have any cracks. I've also tried leaving the 2 bolts a little looser to no avail. Any thoughts. It drips out pretty steady.
    Fuel Pump
    Nevermind. When I took apart and cleaned he pump, I put the plastic spacer on wrong and the little slot on the block side didn't line up. All is good now.
