I bought a used F150TXR 2006 and also bought a tach 6Y8-8350T-11 that has a single square 4 pin plug in the back. Which command link is needed?
Need Command Link
Here is an illustration that depicts how to connect your tachometer to the motor.
2014 Yamaha MRP Catalog
Is this what you are asking about?
Sorry, I should have asked, "what's the part number?" Which I see is 6Y8-0E83R-61-00Originally posted by boscoe99 View PostHere is an illustration that depicts how to connect your tachometer to the motor.
Again, thanks so much.Last edited by Reel Kahuna; 02-01-2016, 07:18 PM.
6Y8-0E83R-61-00 is the part number for the single gauge round kit.
See this page. 2014 Yamaha MRP Catalog
The part number for the tachometer itself is 6Y8-8350T-20-00. You have a -11-00 round tachometer which is an earlier version of what became the -20-00 that is in the present kit.
If you have the tachometer by itself you would not buy a kit for the installation of what you have.
Keep in mind I linked you to the Yamaha 2014 MRP catalog. The 2015 catalog has been removed. For now anyway.
I was able to talk to the seller who said he just used the wires from the 10pin harness from the motor to the binnacle. Dark Green and Yellow to the tach. Doesn't sound right, but is it?
The seller does not know what he is talking about.
There are four pins in the Command Link gauge.
Two are for electrical power (yellow = 12 volts/black = ground) and two are for the data (blue and white).
Power (yellow and black) comes from the key switch. The data (blue and white) comes from the connector on the motor in the case of a 2006 F150.
The data wires normally have a 120 ohm resistor at each end. You might get away with installing a 60 ohm resistor between the blue and white wires adjacent to the tachometer.
I showed you the Yamaha way of making the connection. There are other ways to skin the cat.
Okay, this is what I found. But no part numbers
Is this list correct?
Part Number: 6Y8-0E83R-61-00
Kit Includes:
Qty Description
2 Multi-Hub Assembly
1 Power Lead, 8 ft.
1 Cap, 2 Pin
4 Cap, 4 Pin
1 Pigtail Harness, Engine to Rear Hub, 9 ft.
Not needed
1 User Operation GuideT-20-00
1 Tachometer Assy.
