hello again. i am in the middle of cleaning/rebuilding the carbs on my 1996 150hp. one of the needle valve seats seems to be leaking. i put a vacuum gauge on to check and it cant hold air. all 5 others seal fine. if i put my finger over the top of the assembly it still leaks. thats why i think it is the seat not the needle. i looked around online and i cant seem to find a replacement seat. yamaha doesnt include it in their carb rebuild kit either. 2 questions... how do i remove and install new seat? and who sells them? thanks in advance for the help.
1995 c150tlru needle valve seat
Looking at the parts fisch:
1996 C150TLRU Yamaha Outboard CARBURETOR Diagram and Parts
Its not replaceable. The needle itself usually wears out way before the seat does.
The needle itself usually gets indented (is the softer of the two) and wears out first.
**Did you try putting another float and needle on the "bad" carb, hold it upside down letting gravity close the valve. You should be able to hold a vacuum doing that (pulling at where the fuel intake line is). Make sure the other side of the two barrel carb is sealed off (so there's no leakage there)
Please update what you find...Scott
in the pic the top needle seems to be a little worn. hope replacement is the cure for the motor stalling when going into neutral issue. cant wait for spring!Attached Files
I can see in your pic's there's a little wear not on the seat but on the side guides of the needle. Of course, too much slop isn't going to help sealing.
I suspect the new needles will probably fix your problem, especially with nice new rubber tips that'll seal better than hardened, old ones...
As noted, I'm looking at the parts fisch and don't see any "seats" available separately.
I know its hard to see down there, but do you see anything unusual in that one hole AND, is there visibly a separate seat or a brass seat pushed into the carb?Scott
Originally posted by TownsendsFJR1300 View PostI can see in your pic's there's a little wear not on the seat but on the side guides of the needle. Of course, too much slop isn't going to help sealing.
*not to beat a dead horse... but it seems odd that a worn seat would mean that a carb goes into the scrap heap. weird.*
Originally posted by rodbolt17 View Postthen polish it.
I use fine grit valve lapping compound and Q tips.
cut the Q tip in two.
dip the cotton ball in lapping compound.
chuck it in a drill.
polish the seat.
then CLEAN CLEAN CLEAN it to remove any lapping compound.
Seats are usually damaged by someone trying to clean them with objects they should not be shoving down in them.
keep hard wires and other things out of brass seats and jets.
Even damaging the shape of fuel jets messes up the flow rates designed from what I have read, so drilling out a jet is not the same as buying a larger jet
ÂÂÂ
