Hi all - Hopefully there are still some experts around in the sea of spam posts that might have some guidance for me
Engine - 2003 Yamaha F115
When I fire up the engine cold the motor voltage reads 12.8 to 13.2 volts and stays there. I am under the impression that idle voltage should be around 14.2 volts or so. The boat will get on plane just fine and has no problem maintaining 14.4 to 14.6 volts when above 2,500 rpms or so. Sometimes when returning to idle I will see the voltage drop to low 12's or high 11's and the motor will sputter, misfire, and die out. Fires right up afterwards. I did checks on the stator, pulser coils, and rectifier and they seem to be functioning.
I noticed that when I unplug the water temperature sensor at idle, the engine will increase both rpms slightly and voltage will increase to 14.4v, the engine will generally sound stronger. The water temperature sensor, and the air temperature sensor both read 4.73 volts (unplugged) when the ECU is awake (engine not started). The TPS sensor reads 4.99 volts.
Can anyone explain to me why motor voltage will increase when the water temperature sensor is unplugged? Also would this sensor robbing the voltage from the motor be enough to cause a misfire and stall out sometimes when returning to idle?
Thanks all
Thanks all
