I removed the cylinder cap from the tilt/trim assembly with a pin wrench. What's next? Should the trim cylinder assembly come out or is there more disassembly required? It seems to be stuck and I do not want to force it. This is the tilt/trim unit off of a Yamaha 2006 F90TXR.
Tilt/Trim Cap Removed - What's Next?
Here's the parts fiche for your unit:
2006 and Later F90TXR Yamaha Outboard POWER TRIM TILT ASSY 1 Diagram and Parts
Someone else will have to chime in re your question, (IDK)...Last edited by TownsendsFJR1300; 01-24-2016, 07:17 AM.Scott
put fluid in the pump and turn the pump to use hydraulics and push it out.
watch out for the 6 balls. don't lose them.
you will then need two more special tools to disassemble the tilt ram.
ÂÂÂÂÂÂÂÂÂÂÂ
