Trim Tilt help on my 2000 OX 66
  • Trim Tilt help on my 2000 OX 66
    61 A -43800-25-4d
    2000 OX 66
    Trim & tilt seals leaking , Changed
    release screw welded shut , now stripped , tried drilling and really messed it up ,
    I should have left well enough alone since it was working , BUTTTTT NO , Anal me wants everything working as it should
    Now I have too remove trim & tilt , too correct release screw , or replace with a good used unit
    put a socket on bolt head starboard side , it snapped un even , other bolt came out ,
    Never touched port side but looks like previous owner snapped both bolt heads
    first section of the bolt has no thread as it go thru assembly , threaded portion is the trim tilt not the trim & tilt support bracket
    should I try too drill them out ??
    Lower section of trim & tilt is that a long bar held in place with C clamp ?
    if I can separate enough too put a sawzall
    really gave a job too myself
    thanks
