hello. i was having idle problems this past summer with my 1996 yamaha c150tlru. sooo i figured I would clean the carbs over the winter... well after opening the bottom carb i found one carb bowl is hangining lower than the other. The manual says to set float height at 16mm, which they both are. my question is how do i determine what height to set the float "drop"? which one is right? or could they both be wrong? ideas?
