HELP Please! My own mechanic has given up!
  • HELP Please! My own mechanic has given up!
    This is regarding a 2005 Yamaha Z200TXRD Serial number- 6G6X1020793 a 2 stroke HPDI. My mechanic has gone through the motor extensively.
    I have owned this boat for almost 4 years. Prior to that it was used by another guy for occasional use during our fairly short season on Cape Cod. When I bought it, it had less than 500 hours on it and now it has less than 600 hours. This issue has nothing to do with where the engine is mounted. It is not the prop either. I have uploaded a video to youtube and here it is: https://youtu.be/l98g7DZaXSk?si=rvfgHYCXVfha_RYz
    The main point you have to understand and as you can see in the video, is that when I move the shift lever up past 3000 rpm, the engine starts to accelerate on it's own, first slowly and then it gets past 4000 rpm and then it races as if I jammed the shift lever to full throttle, but there is no more forward momentum. Again, I am not touching the throttle at all. Last year we installed a brand new lower unit and trim & tilt assembly. At this point I wish I didn't because I could have saved that for a new motor instead but when I have a Yamaha with less than 600 hours on it, I assume that it is worth saving.
    I grew up on boats, I know a lot, yes, but I am not a mechanic and this is way beyond my ability to solve. I feel like this is a sensor or switch or something like that affecting fuel injection. I am very frustrated and clueless and done grasping at straws. Any help you can give me is very much appreciated,
