Encountered something recently that seems to be persisting. It happened 4 times last I was out. Engine starts fine, no alarms, nothing, randomly engine will shut off and gauges will turn off as well. I flick the key, gauges pop up and engine fires up on turn. There's no pattern or reason, happened once while underway, once in reverse, 2x at idle, and once on muffs when boat was on blocks.
My first step is to replace wire ends on battery and to selector as 2 of the ground wires look a little rough. Will attempt to look for my multimeter and test resistance of each lug/connector. I will also check the ground and connections on the engine block that go to the battery. My thinking is it's some bad connection as the gauges were turning off too. Is there anything I'm not thinking of that I should also check? OB is always serviced on schedule but these wires are old from previous outboard.
