Power and technical data comparison F40NET1 (40HP Supreme) and F70AETL
  • Power and technical data comparison F40NET1 (40HP Supreme) and F70AETL
    Hi all,
    if we compare the technical data of the F40NET1 and F70AETL, we can see the engine is completely the same (16 valve engine), except the installed air restrictor. Has somebody the power diagramms with and without air restrictor available? The air restrictor is made of aluminium disc with a center bore of 12.8 mm and 8 surrounding holes with diameter of 3,2 mm.
    Thank you and best regards.
