Where is the best place on the engine to attach the water pressure gauge hose. 2004 Vmax V150TLRC
Attach Water PSI Gauge Hose
Originally posted by amahaork View Postutterly useless feature. follow motor maintenance schedule and pressure always will be good.
Have you never heard of a water pump failing to do its job between service intervals? Some boat in sand, mud and muck and the cooling system suffers.
Those that use a pressure gauge can get more miles out of their impeller. By monitoring the output via a pressure gauge. I could get three or so seasons on an impeller before the pressure would start to fall off. I then knew it was time to change the impeller.Last edited by boscoe99; 12-04-2024, 12:15 PM.
I picked up some seaweed once that plugged off the intake, when the over heat horn went off I shut down the motor and tilted it up to clean off the seaweed.
set it back down and fired it up, but no water flow at idle, but did get some at high rpm.
once I got back home, I pulled the pump and the impellor had melted.
if you have a pressure gauge you need to keep and eye on it or set up an alarm to make you look.
if I had looked at the tell tail often enough maybe I would not have had that melted impellor problem
Originally posted by amahaork View Postbe extremely, super extremely, careful removing the plug. very little thread on aluminum block, and plug is steel. and corrosion is possible. if you cannot remove it with minimal torque applied, then abandon it.
ÂÂ
