The engine is a 1990 ProV 150.
A couple days ago while I was running across the lake I had a sudden loss in power. The boat was cruising at around 4000RPM when all of a sudden I felt it shudder and drop to around 3200RPM. I tried to give it a little more throttle but all I could get it up to was 3500RPM, but it would surge like it wanted to run faster, but wasn't getting enough fuel. I pulled the throttle back and idled to the ramp with no isues.
Today is the first day I get to work on it to try and track down the problem. 3 months ago I did a complete rebuild of the cards with all new parts, so I'm hoping its not that. My first thoughts are rebuild/replace fuel pumps. Check high speed jets in the carbs. Compression check. Test spark. I've already replaced every fuel line in the boat, and there is a water separator installed. I also run ethanol free fuel.
If anyone out there can think of anything else to check please let me know.
