first post. first cold start of morning, wont stay idle, just start and die. open throttle a tad and will run /idle after 20 sec. no problem rest of day, starting/running. suspect iac valve. pulled it, ck ohms 35ohms ea coil
touched power and ground quickly several times, no movement either way
has power at connecter harness. can i confirm failed iac with bench test?
