My Sx250 (2000) is intermittently losing power.. ""almost like a coil misfire on a car""" ... I checked fuel pressure and all filters ... would a Winky-Blinky be a useful diagnostic tool ???
Winky Blinky
Yes .... today ran the boat 0ver 3 hours and ran great ... thinking maybe an injector issue that may have cleared or maybe just wishful thinking .... On another note MR BOSCOE99..... The information you sent me on the Tachometer and the 3 flashing bars was the reason I was able to fix that problem ... You set me in the right direction .. You're a good teacher !!!! Thank you sir !
Originally posted by ttles714 View PostYes .... today ran the boat 0ver 3 hours and ran great ... thinking maybe an injector issue that may have cleared or maybe just wishful thinking .... On another note MR BOSCOE99..... The information you sent me on the Tachometer and the 3 flashing bars was the reason I was able to fix that problem ... You set me in the right direction .. You're a good teacher !!!! Thank you sir !
With Boscoe99's help I was able to understand what the flashing bars meant ... The 3 flashing bars meant that the engine mounted oil tank was low ... In checking, I found that the main oil (hull mounted) tank was not pumping oil to the smaller engine tank ... Even so when activating the emergency switch .. I could hear the pump running ... so the short story is I would like to kill the guy who decided to mount the oil tank where it is in the boat ... cleaned the tank and filter and all is good !!
ÂÂÂÂÂÂ
