It seems there is a 14mm plug for draining the oil. Was thinking of attaching a adapter to tubing to drain into bucket. Will a 1/2" nylon adapter fit well enough since 14mm is .55 inches? Figure you can wrap with teflon tape to make difference.
Is this drain plug located inside the round black exist at the bottom of the motor? I have not raised it up to look inside yet but from the manual looks like it it has to be inside the rubber outlet I see there.
