I need some help finishing a install on some analog gauges. I have a 2016 Sylvan (smokers craft) 8520 cruise and fish pontoon. It is rigged with a Feb/2015 F70LA outboard. Only a Tach and Fuel gauge came with the boat. Both were analog. I have installed 7 gauges (Teleflex Sahara Series Tach, Oil Pressure, Water Temp, Fuel, Voltmeter, Trim/Tilt and 35 mph Speedo). I have all the grounds, Ignitions and Illuminations wired up. I have not ran the boat, but the Fuel and Volts work and all the gauges light up. I ran the speedo tube to the back and hooked it up to the tube with a blocked off barb in the front of the engine. I also ran 3 wires to the back for trim, water temp and oil pressure signals to send through.
My questions are:
What wires do I use in the engine harness for Trim, Water Temp and Oil Pressure gauges?
Do I need sending units for any of my gauges to work?
If I do need sending units please advise the Part #'s and were they would be installed on the engine.
Thank you in advance
My questions are:
