Going back together with intake manifold plate and three carbs looking to find the torque procedures on those parts
Torque specs 2005 Yamaha 2stroke 50hp tlrd
Thank u I usually do that but been noticing that there is a issue with those intake manifolds breaking on middle cylinder by the oiler just thought maybe had to do with torque or maybe it’s just a poor design and it a heat issue not sure ….. would u have the answer as to why they break there ?
here is what a 1997 service manual says, but I have no idea if it would be for your 2005.
you really need to get a service manual for your motor
Originally posted by Journagan View PostThank u I usually do that but been noticing that there is a issue with those intake manifolds breaking on middle cylinder by the oiler just thought maybe had to do with torque or maybe it’s just a poor design and it a heat issue not sure ….. would u have the answer as to why they break there ?
Share a picture if you can.
Pan,
What are your thoughts as to all four bolts being left out upon the reinstallation of the Boeing door opening plug? By a Boeing employee reportedly. Could have been more disastrous if the plug had departed at a higher altitude.
Sad to me seeing what Boeing has become.
One of the guys working on it texted a picture of door closed to the guy on the next shift who was going to finish the job...but the lock bolts were not installed. There should have been flag tape tied to the door with the bolts in a parts bag tied to the door as well. Where are the bolts now?
So many things went wrong here its unbelievable. You can have the best quality program in place but humans will find a way around it...never fails.
Luckily no one got killed. Boeing is trying to build to many airplanes in too short of time and this is the results when everyone is in a hurry...
ÂÂÂÂ
