I would appreciate thoughts on the following - did a compression test on this motor and the top 4 cylinders show 120 while the bottom 2 - # 5 and # 6 showed 110 and 115. Thought possible head gaskets so I pulled the heads. The combustion chambers for these 2 were whistle clean while the other 4 shoed carbon on piston tops. And the air box ports under both # 5 and # 6 had a lot of raw fuel in them so thinking this is washing the bottom cylinders. Head gaskets are OK and all cylinders look fine - good cross hatch still , no scores, no piston wear no bearing slop.
Thinking there is a rich fuel condition - winky blinky did not show any codes.
o2 sensor new late 2014. Have not checked injectors but they were cleaned and tested in spring 2015 - all Ok.
Any ideas on a rich fuel condition? Wondering if a fuel pump is leaking fuel into the # 6 cylinder and its crossing over to # 5?
