2014 F300XCA's
Shortly after turning on the KEY but prior to hitting START, the YAM engine gauge panel will come to life. And then the ALARM horn sounds. The pre-start VOLTAGE is fine. The OIL LEVEL is fine. The engines then start fine and idle like glass. Both cooling telltales stream water. The OIL PSI is fine. The indicated TEMP is fine. Yet the alarm continues.
When I then select CURRENT ALARMS on the panel, there are NONE present. When I hit TROUBLE CODES, there are none present.
What the hell is going on?
