Hi all
I am having an overheat problem on my 90hp Yamaha outboard, particularly when revving over 3500 rpm. History of the problem is as follows:
had a winter service done with new impeller put in, then took it out and had overheat issues at around 2500 rpm. Noticed the tell tale was very weak in the water but strong with the muffs on.
I then replaced the head gasket and water jacket gasket and poppet vale and spring. Thermostat was opening fine with warm water test and cleaned out all water passages that had a bit of sand and corrosion build up but nothing too bad.
took the boat out and now only get the overheat alarm at about 3,500 rpm with steam coming out of exhaust ports. Cools itself after a minute and then can carry on cruising below 3,000 rpm. Although I do notice a bit of steam coming out the exhaust port but no alarm. If I try and push it further then the alarm will go off again.
I called the first mechanic who did the impeller change and he said it needs another new impeller. Not sure if he is taking me for a ride or not!
Like I mentioned with the muffs on the tell tale is very strong but not in the water where it is weak at any rpm range. Could it be that it needs a new impeller so soon? On the muffs the tell tale is cool to the touch and water jackets remain cool to me touch.
any help would be appreciated!
