One of my engines on a twin engine setup doesn't start up on the first crank if it sits for more than 2 days. After trying to start it I let it sit for about 10 minutes than try to start it again and it starts up. Runs good after it starts. If I start it every day it will start right up. Both water separator and primary filter on both engines were changed recently. Both engines are running off of 1 fuel tank with separate lines. Other engine starts up with no problems. Does anyone know what could be wrong?
2013 F70la not starting on initial crank
if you have spark when it will not start,
then it has not enough fuel or too much fuel to the air in the cylinders to fire properly.
rail pressure would be the 1st thing I would check.
if that is good then injectors firing.
does it help to pump the primer bulb?
maybe the VST lost it's level over time. but I cannot think of how that would happen
