F25SEHA Multifunction Tach Install
  • F25SEHA Multifunction Tach Install
    I have a 2013 F25SEHA and am in the process of booking up a Yamaha Multifunction Tach. My engine harness is the 6BL-82590-40 and appears not to have the 10 pin connector for the control box. I am trying to find find where to tap the Tach signal wire into. I checked my rectifier/regulator, it has the red and black wires (DC output) and a pair of green wires connected to the stator / generator (AC from stator). There are two additional pairs of wire coming off the stator that I assume is a possible source for a Tach signal. As far as I can tell, the stator and regulator are the same for the F25SEHA and the F25LA, if I could find a schematic for an F25LA, I could figure this out....Sorry for being so long winded....
      Awesome, thank you!
