have 175 hpdi idles great!!! top end great! when hitting throttle to get up on plane it cuts out like off on off on.Then takes off and runs great. cleaned gas tank and changed all filters..... no water present all lines hold pressure. does not lose prime. was thinking electrical but I am clueless with these newer motors. It will do this everytime i go to take off hot or cold
HPTI stalling on acceleration
so, are you sure the rail pressure holds steady while this problem is happening?
if it does, then you are left with injectors not firing on all cylinders or spark/timing problem.
those motors limit RPM while in neutral by dropping some more cylinders,
so maybe a switch that tells the ecu it is in gear is getting flaky.
just a wild guess
Is this a new or on-going problem?
Are you sure you're not confusing a problem with the cylinder cutout feature? In the 2,000-ish RPM range, it doesn't run on all cylinders so if you throttle up too slowly it will do exactly as you describe.
EDIT: I should say that "I think" you have cylinder deactivation in the 2,000-ish range. Mine does and I "thought" your engine was similar in that respect. Check into it.Last edited by DennisG01; 10-19-2023, 08:52 AM.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
If it's cylinder deactivation (Google or your service manual would likely clarify that) you would NOT notice it with at least "medium" acceleration - only with slow acceleration.Originally posted by skeeter74mph View PostWe’ve had this boat for four years and never had a problem like this. Just started this year. If it was a cylinder deactivation, would it only happen on a slow throttle increase or on a floor throttle increase. Is that since there something I can change on my own?
If this is not the case, then hook up a fuel pressure gauge - monitor that while accelerating. They are not expensive to buy.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
ÂÂ
