Originally posted by DennisG01
View Post
Your quote:
"On the other hand, if you can clean it up really well... REALLY well... then I think your idea of epoxy (like Marine Tex or PC-11, etc) and a stainless washer will most likely be just fine. You won't need (or want to use) much goop - and even though it will likely be cured in a day, I would give it at least a couple days for good measure. Use your drain screw to hold the washer gently, but snugly, in place while it dries. Apply some wax to the screw threads - just in case a little goop squeezes out on the threads, it won't stick."
Very good plan if going to try the washer repair.
I still think that getting it cleaned up and as flat as possible first would be needed so that the washer will end up being stuck where it needs to be.
What to bond it on with is another thing...things dont like to stick to stainless well. I definitely would not use JB Weld as it gets brittle.
