Difference in B7HS -10 and BR7HS-10 Spark plugs
  • Difference in B7HS -10 and BR7HS-10 Spark plugs
    My C40TLRX calls for B7HS, even has a sticker on the motor.
    and I clicked on those on the parts web page for my motor when I ordered them, but I got the BR7HS.
    will this be a problem to use them or do I need to get the B7HS?
    I am sure the R stands for resister ,
    Would the resister cause a higher spark voltage?
    From what I remember on automotive Nonsolid wires and resister plugs helped reduce noise in radios.
    looking to see what all this parts web site shows for the BR&HS plug it is higher HP motors 150hp and 200s
    https://www.ngk.com/what-is-a-resist...le%20operation.
    https://online.flippingbook.com/view/17923346/4/
      This place is getting ridiculous. Onerous. Keeps blocking links to useful websites.
        NGK says a non resistor plug provides more energy. Appears that you got the wrong plugs.
        Although in reality it might not even be noticeable.
          I guess I will try them and see how it goes
            Amazon has them. The resistor plugs will work.
            https://www.amazon.com/NGK-B7HS-10-S...s%2C279&sr=8-1
              That's a few times you said that...I don't seem to have any trouble???
                Amazon has them. The resistor plugs will work fine..
                https://www.amazon.ca/NGK-B7HS-10-St.../dp/B0000AXR69
                $13.22 a plug, that is crazy
                  Sorry..wrong link I posted. Look on Amazon.com
                  I just changed it in the post.
                    clicking the Yamaha Parts at top of page shows them for $4.20,
                    but you may get the BR7 instead. Like I did
                      Forget that..they want $20 to ship. Looks like Napa online has them $4.29 USD plus shipping, dont know how much that will be.
                        I was ordering a new set of seals and housing for my drive shaft anyway, and also a set of plugs for my brothers C60 (B8) along with the B7s for my C40.
                        shipping was $9.95 and then taxes.
                        Will try napa next time is I am not ordering other Yamaha parts
                          Post #2 above is on hold pending an approval. All I did was post links to two NGK websites.
                          It is all highlighted in green. Unapproved notice is provided.
                          Do you see a post #2?
                            Let me see if I can trick the system.
                              post #2 is you complaining about them blocking you post
