my parents boat started having an issue. it has dual 250hp ox66. when cruising both engines will randomly suddenly power down at same time but still run similar to overheat. the warning buzzer will sound (it only works for port engine). the buzzer will keep going and the engines will be unable to power back up over ~2k rpm until you put the engine into neutral. soon as you put in neutral, the buzzer will stop and you can go again.
unsure what would cause this and it pretty random. over about a 20 minute test run at different rpms, it did it about 5 times. sometimes go few miles in between, sometimes less than half mile
my first thought was overheat but never had both engines do it at the tame time, every time. and the buzzer only stops when putting it in nuetral? the engines no longer have the oil system, we premix it, and those sensors have been bypassed for years.
i have aftermarket digital gauges that dont really work correctly and i been working with the designer to work out the kinks. my temp gauges are very unreliable but do occasionally show actual temps but usually are far off, but i think it MAY have gotten up to 190* occasionally on one engine. the water pressure show 19psi on one and 9psi on the other when cruising, recently replaced waterpump on one engine is reason for such a difference. have good fuel pressure
